ES64F4 094 & 096 nach Kroatien überstellt
Gestern wurden als Lp 95735 die beiden Siemens Dispolokomotiven ES64F4 094 und ES64F4 096 aus München kommend via Salzburg zu den HZ nach Kroatien überstellt.
Toma
Re:
Beitrag von Toma »
hello all!
Both locomotives arrived to Zagreb on sunday, 20th november; now they are stored in the mai depot on Zgb Marcaling Yard. According to availabe info, locos will be in use from 1st december.
First they will be tested on 25kV network, and after that will be transfered to Rijeka line (3kV=); on ha line that class of the locos were allready tested.
I have to say that HZ has VERY critical shortage of old italian locos (HZ 1061) on the Rijeka line; just 8 or 9 locomotives are in use! Also, two 2063 (GM EMD Co'Co') are working on Rijeka line.
According some very unofficial info, locos will be in Croatia for 6 monhts, and Hz has some plans to buy those two engines! The HZ numbering will be HZ 1241 001 and 002.
regards from Zagreb
toma
Diesen Montag wurden 189 921 und 189 922 nach Zagreb überstellt um die bis dahin an die HZ verliehenen 189 994 und 189 996 abzulösen, welche gestern während eines Zwischenstopps in Salzburg Hbf. gesichtet werden konten:
HZ 189.996+994 Sbg Hbf 01.03.06.jpg (69.09 KiB) 8554 mal betrachtet
